Exit to Current Directory When Started from DOS Prompt
Is it possible to configure V to exit to the current directory when started from a DOS prompt rather than the directory V was started in if you have browsed to another?
Re: Exit to Current Directory When Started from DOS Prompt
No. There is no way of doing this.Is it possible to configure V to exit to the current directory when started from a DOS prompt?
The best you can do is to open up another DOS prompt in the current directory by pressing Alt+C
