Version 12 Release
Locked
Version 12 Release
V12 has been released and can be downloaded from the Downloads page.
If you are currently running V11 or a V12 beta, you can upgrade by selecting Check for Updates from the Help menu.
The main new features in Version 12 are:
  • Command Line Search/GREP
    Support for Everything Search
    Support for 7Zip files (.7z)
    Synchronized scrolling option when viewing multiple files
    Data displayed with GridLines can now be exported to a CSV file
    Right-click on a User Command to run as Admin
    File Mask history can now be set to 1 (effectively disabling it)
Please see the What's New in Version 12? section of the V Help file for a more detailed explanation of the new features, including a list of all the new command line options for search/GREP.
Thank You
V is now entering its 14th year and I would like to thank all users for their support through the years.
If you have a suggestion for a feature that you would like to see in V13, now is the time to tell me. If you have already told me, then it wouldn't hurt if you told me again :)
All the best for 2011.
Locked
