folder tabs aren't always being saved between sessions
jstrunk@pressganey
Post by jstrunk@pressganey »
I am on XP SP3, V Version 11. Sometimes my saved folder tabs are not reappearing between V sessions. It seems to be sensitive to how I start V - from a V shortcut, direct from Explorer double clicking on v.exe, from windows explorer viewing a text file.
Re: folder tabs aren't always being saved between sessions
Do you mean that the number of tabs saved is incorrect or that the folders in the tabs are nor restored?
Can you give me a specific example of the problem? Can you reproduce it?
Do you ever have multiple copies of V running at the same time?
