Shift Double-Click not working
jko
Post by jko »
Hi,
I recently upgraded from V7.2 to V11 (current version). In the past (with V7.2), I could double-click a file to view it in V; if I wanted to execute the file (using the normal Windows app for that file type), I could just shift double-click.
Since I have upgraded to V11, however, this no longer seems to work. Was this shift double-click feature removed? (If so, why?)
Or do I need to configure something differently? Or is there another way to accomplish this same ability (as there are some file types that I want to be able to view or execute, based on the need of the moment)?
Thanks much, John :)
Re: Shift Double-Click not working
In V11, the Shift+Double Click functionality has now been replaced by Ctrl+Shift+Double Click.
Shift+Double Click now ensures that a file is always opened in a new window - overriding the Use Existing File Window ... option in the Window Layout tab of Preferences.
Note that you can also use Ctrl+I to execute a file.
