dual filearg user cmds using finder result
yerrbjr
Post by yerrbjr »
Today I had a need to diff 2 files, where one of the files appears in the std v window (1 of 2 in dualpane), the other which appears in the file finder result window.
There doesn't seem to be a way (e.g., user arg '%3F') to reference a file arg in the find result window.
Is there a way that I have overlooked?
Re: dual filearg user cmds using finder result
Unfortunately, this is not possible with the current version.
I will look at doing this for V12 - but that won't be available until the end of the year.
