How do I copy a column of text?
I can't seem to figure out how to copy columns of text (not entire lines)?
Re: How do I copy a column of text?
You need to have the Ctrl key pressed as you select the text with the mouse.I can't seem to figure out how to copy columns of text (not entire lines)?
This is only going to work if the document is a table or spreadsheet with fixed columns, though, yes?
Ken
Ken
It will work with any text file.This is only going to work if the document is a table or spreadsheet with fixed columns, though, yes?
However, the data copied will most likely only make sense if it is in table format to begin with.
