Installing version 15
I am currently running V ver.13 (registered) and will soon purchase ver.15. I would like to install the new ver.15 in a different directory so as to be able to keep the ver.13 available. Will that cause any problems?
Re: Installing version 15
No, you shouldn't have any problems.I would like to install the new ver.15 in a different directory so as to be able to keep the ver.13 available. Will that cause any problems?
The only thing you should be aware of is that both versions use the same Registry key to store the settings. So you can't have different settings for the different versions.
