Moving V to another PC?
Post by vuser »
I purchased a license to V in June 2009, now I would like to move it to another PC, how do I do this?
Re: Moving V to another PC?
You need to re-install V on the new machine and re-enter your registration code. The latest version of V can be downloaded from:
http://www.fileviewer.com/Download.html
Unfortunately, there is no easy way of transferring your current settings to the new machine.
If you know how to use the Windows Registry Editor, you can export the following key on your current machine and import it on the new machine:
HKEY_CURRENT_USER\Software\Prineas\FileViewer
Alternatively, you can look at using the VClone program which must be run from a Command Prompt:
https://oddslot.co.uk/
