dos prompt not working
lewfoo
Post by lewfoo »
It appears that the right-click Explorer menu item "DOS Prompt Here" fails to open a DOS command window in the selected directory. When choosing this option, the DOS command window does appear, but the current directory is "C:\Windows\system32" instead of the current 'V' directory chosen.
I've used this utility on other Win7 computers, and it works flawlessly. But on this new computer, it does not. There must be something I'm not setting up, but I've been unable to discover what that is.
Thanks.
Re: dos prompt not working
I assume that "DOS Prompt Here" is a third party extension. Is that right?
Do you have the same problem when using "DOS Prompt Here" from Windows Explorer?
Are you running the 32 or 64 bit version of V?
