Version 14 - Service Release 3
Locked
The third service release for Version 14 is now available on the Downloads page.
Service Release 3 adds the following:
  • URL Path added to the File->Copy to Clipboard menu
  • V will now prompt for a password if you browse network paths that require authentication
  • Expand/Collapse on single click added to the Explorer Options
  • Expand/Collapse Folders options added to the right-click menu of the Explorer tree
  • FolderTabs are now multi-row with an option to make them single row
  • Multi-line CSV fields are now disabled by default with an option to enable them
SR3 also fixes the following problems:
  • Extracting from some split RAR files
  • Alternate Data Streams (ADS) for folders were not being displayed
  • Support for tar/gzip files greater than 4GB (only in x64 version)
Locked
