Duplication of Directory names
I have an issue where sometimes the directory listing on the side is duplicated in My documents. I don't see it happening for other disk drives or libraries. It's not really a problem as I ignore it but I thought I would pass it on to you in case you wanted to look at it. I'm using the 64bit version.
- Attachments
- duplication-fileviewer.JPG (61.99 KiB) Viewed 22937 times
Re: Duplication of Directory names
Are you running the latest version (V14 SR1)?I have an issue where sometimes the directory listing on the side is duplicated in My documents
yes - running with latest code.
Do you get the duplicate names as soon as you start V and expand My Documents or do the duplicates appear after some time?I have an issue where sometimes the directory listing on the side is duplicated in My documents
