Crash on View Clipboard
mshilling
Post by mshilling »
See attached screenshot.
Clipboard contains an image file.
Re: Crash on View Clipboard
Can you reproduce the problem? If so, exactly how did you put the image in the clipboard?
What version of V are you running and on what OS?
Please select "Send Error Report" from the Help menu.If there are any crash files in the file list (Crashxxx.dat), please send them to me.
mshilling
Post by mshilling »
Was consistently consistently reproducible. This morning it's functioning fine, but nothing changed. No reboot over the weekend. Image added to clipboard from TechSmith SnagIt 10.0 build 788. Running V Version 12 (SR1) (x64) on Win 7 Enterprise 64 bit.
No report files to send. Will monitor and report back if it reoccurs.
