always on top
fpefpe
always on top
Post by fpefpe »
Hello -- not sure if this is a bug, but it a problem
As it turns out I had the "always on top" option checked -- while browsing file, I clicked on a RAR file and everything sort of froze -- its was the rar file in question -- it had a password on it and the password prompt window could not get focus and I could not move the V window to see it -- I tried to close the V window but that did not work -- so I had to restart the computer
even if "always on top" is set should the password prompt window get focus?
Re: always on top
Looks like a bug. I will try to fix it in the next release.
Note that the password window should still have focus, so you should still be able to enter the password (even though you will not be able to see what you are typing).
