Controlling title bar
Bill.Raynor
Post by Bill.Raynor »
Is is possible to control what gets placed in the title bar? If I am working in a directory with a very long path name, the actual filename is beyond the right hand edge of the title bar. thus when you have multiple files from the same directory open (e.g. looking at code) you can't tell which one you are looking at...
Bill
Re: Controlling title bar
No.
I will see if I can do something about this in the next release.
In the meantime, if you hover the mouse over the corresponding V icon in the Windows taskbar, it should display the full path.
Bill.Raynor
Thanks, I'll keep that in mind.
