Roll out software MSI
Stuart_mullock
Post by Stuart_mullock »
Hi
Has anyone created an MSI to roll out V File Viewer?
We've tried creating bat files to roll out through AD using the /auto switch but only the dll's are copied.
When trying to install after a partial install the program reports the program is already installed. Is it possible to force a complete install?
We're trying to roll out 150 copies so manually installing the app isn't really an option.
Cheers
Stuart
Re: Roll out software MSI
There is a problem with setup.exe - I will send you a new one.
