Windows Explorer
fpefpe
Windows Explorer
Post by fpefpe »
Hello -- Sorry if I missed it, but is there a way to replace he windows explorer with "V"
Re: Windows Explorer
If I understand you correctly, the answer is no.
But why would you want to replace Windows Explorer?
You can simply create a V shortcut on the Desktop and launch V instead of launching Explorer. Isn't this enough?
fpefpe
Post by fpefpe »
Hello --
Thanks for the reply
Before using V, I been using powerdesk -- It has an option to have it run anytime anything in
windows runs explorer.exe -- It must be a registry setting -- So with this powerdesk option set,
if I click on the "my computer" icon (xp desktop) powerdesk is executed
If this is not possible, I would suggest it as something to add in future releases
Thanks
