File mask box
glyn
File mask box
Post by glyn »
Hello
I have been using V under Windows 7 64bit and I very happy with the program.
One issue I have noticed is when I have selected to have the drive box shown on the left, the right file mask box (2) has its drop down arrow missing/cut off.
It looks like the Directory list box is not resizing and is pushing everything to the right.
Regards
glyn
Re: File mask box
Unfortunately, I can't reproduce the problem. Are you using the standard Windows theme or have you customized your appearance?
Are you saying that if you resize the window, the size of the Directory box does not change at all?
If possible, can you send a screen shot of the top of the V window to v at fileviewer.com ?
Re: File mask box
After further investigation, I think I have found the problem.
It will be fixed in the upcoming Version 13 beta.
glyn
Re: File mask box
Post by glyn »
FileViewer wrote:After further investigation, I think I have found the problem.
Hello
It is the same with a default MS Aero theme or the Basic theme which is what I use all the time.
Do you still need any screenshots?
Re: File mask box
No, that won't be necessary.
glyn
Re: File mask box
Post by glyn »
Hello
Fixed in V13 b1.
many thanks Charles.
