I have now seen where the V view of c:\windows\system32 .. is diff then when you go to My Computer .. and view the same directory ..
I have a screen snap .. I hope it gets attached...
I have looked at options, help .. and still do not understand why this is happening ..
This must be a W7 issues .. as I have never had it with years of use with previous Windows versions..
Help as I have become dependent on V .. and with the current mandate to use W7 .. it is a must to work..
tanx.. Don
W7 diff file views
W7 diff file views
- Attachments
- 6-24-2011 9-50-28 AM.gif (92.61 KiB) Viewed 14444 times
Re: W7 diff file views
This is because you are running the 32 bit version of V on 64 bit Windows.I have now seen where the V view of c:\windows\system32 .. is diff then when you go to My Computer
Basically, 32 bit programs do not have full access to the 64 bit file system.
Click here for further details: http://www.fileviewer.com/V64.html
To fix the problem, you will need to install the 64 bit version of V.
