Version 12 - Service Release 1
Locked
The first Service Release for V12 (SR1) is now available from the Downloads page.
If you are currently running V12 or V11, you can update by selecting "Check for Updates" from the Help menu. If this displays an error message, please download the update from the Downloads page.
The service release is primarily a bug fix release. In particular, an attempt has been made to fix intermittent crashes while tailing files.
This version also allows you to change the font used to display the FolderTab heading by right-clicking on any tab and selecting "Global Tab Settings".
You can also change the font used to the display the Directory/Mask history (at the top of the directory listing) by right-clicking on the small arrow to the right of the Directory box and selecting "Select Font".
If you haven't had any problems with intermittent crashes or if you do not want to change the default fonts, there is no need to upgrade.
Locked
