When doing a search, I uncheck the "Match Case" option.
However, after I exit V and then restart it, the "Match Case" option has gone back to being checked.
The Match Case search option is always enabled!
Re: The Match Case search option is always enabled!
I am guessing that you are using the \ key to initiate the search.However, after I exit V and then restart it, the "Match Case" option has gone back to being checked.
This was added in V8 to easily allow you to toggle the case on a search. That is, using the / key would do a caseless search and using the \ key would enable the case option.
If you do not want this behavior, you can disable it by pressing the Options button and enabling "Disable Match Case Toggling...".
