I have been using the v12 beta4 for several days and have found the program produces an error dialog when closing. That is, when I close the app, I get a Windows dialog saying the program failed. Up to that point there was no indication of failure and the program worked fine as far as I could see.
The Windows dialog offers "view details" and I get:
Problem signature:
Problem Event Name: APPCRASH
Application Name: v.exe
Application Version: 11.0.1.0
Application Timestamp: 4cc65b00
Fault Module Name: ntdll.dll
Fault Module Version: 6.1.7600.16559
Fault Module Timestamp: 4ba9b29c
Exception Code: c0150010
Exception Offset: 00084409
OS Version: 6.1.7600.2.0.0.256.49
Locale ID: 1033
Additional Information 1: 0a9e
Additional Information 2: 0a9e372d3b4ad19135b953a78882e789
Additional Information 3: 0a9e
Additional Information 4: 0a9e372d3b4ad19135b953a78882e789
I just thought I should report it.
V12 beta4 on Windows 7 64bit
Re: V12 beta4 on Windows 7 64bit
Does this happen every time you exit or just some of the time?I have been using the v12 beta4 for several days and have found the program produces an error dialog when closing
Were you using a previous beta prior to beta 4? If so, was that also crashing?
Can you please select Send Error Report from the Help menu. Are any Crashxxx.dat files listed or a V.log? If so, please send them to me.
