Dragging Outlook attachments to V
Post by vuser »
V is great and I use it all the time. But one irritation is that I can't seem to drag email attachments directly from Outlook onto V panes.
I can drag the attachment to my desktop and then onto V, but this is a pain.
Re: Dragging Outlook attachments to V
This will not work if you press the left mouse button while dragging. However, it should work if you press the right mouse button.
That is, drag the attachment with the right button pressed , drop it onto V and then select Copy Here.
Let me know if it doesn't work.
