In file finder, when "Search Inside Archives" is checked, I'd like to be able to exclude self-extracting files (.EXE extension).
This would considerably speed up my most common searches.
(this request was made previously in email; I'm posting it here to make sure it doesn't get lost )
file find - searching .EXE archives
Re: file find - searching .EXE archives
I have actually implemented this in the latest V12 Preview which can be downloaded from:In file finder, when "Search Inside Archives" is checked, I'd like to be able to exclude self-extracting files (.EXE extension).
http://www.fileviewer.com/Beta.html
The Advanced tab of the File Finder now has an option at the bottom to Search the following extensions ...
This contains a list of archive extensions that V will search. If you don't want to search EXE files, simply remove EXE from the list.
