New features in Version 16 are:
- Per monitor DPI support (Windows 10 Creators Update 1703 and above). This means that V will automatically adjust itself when moving between monitors of different scaling
- Shift+click on CSV column header to select entire column
- Copy CSV command to copy CSV columns (with delimiter) to clipboard
- Force CSV can now specify a start line (ie, you can ignore the first few lines)
- Support for BZIP2 compression in AWS files
- Added /QUIET command line option for printing
- Windows XP and Windows 2000 are no longer supported
- Problem with viewing encrypted .7z files
- Incorrect icons were sometimes displayed when searching for files
- You could not print more than 65,535 pages
