File is a mainframe FB file. After setting Flat Text mode and Set wrap length to 80. The chunk size is set to 2mb
Last line is 26215
How do I quickly skip forward to line 150000 without loading the next chunk a number of times? I know the data I want is in chunk 6 on about line 150000. How do I get there quickly?
How to skip forward a number of chunks
Re: How to skip forward a number of chunks
The only way to skip to an *exact* line number is to use the Goto command (Ctrl+G) and enter the line number you want to skip to.How do I quickly skip forward to line 150000 without loading the next chunk a number of times?
You can quickly skip to a chunk by specifying a chunk number in the Goto command. However, if you do this, the line numbering will start from the top of the chunk instead of the top of the file.I know the data I want is in chunk 6 on about line 150000.
