Version 15 - Service Release 1
Locked
The first service release of Version 15 is now available on the Downloads page.
SR1 adds Unbookmarking. This allows you to clear bookmarked lines that contain a particular string.
SR1 also fixes the following problems
  • Highlight All would not always work after pressing Ctrl+PageDown
  • The registration expiry date was not being properly calculated
  • Searching for a regular expression from the search dialog box would crash
  • TabSets were not being saved correctly in horizontal split mode
  • Problems with XMIT files with missing aliases
Locked
