network shares
fpefpe
network shares
Post by fpefpe »
Hello -- window's explorer lets me type in the path box a network share name, ie
\\foobar
and if found, it will display the share available --- I think that it will also prompt for user/password if needed --
can this be added to V?
Re: network shares
window's explorer lets me type in the path box a network share name, ie \\foobar
You have always been able to use a network path in V. V15 added support for password prompting if authentication is required.
Note that you must enter a complete network path - not just a computer name.
For example, you need to enter something like \\computername\foobar - \\computername will not work.
fpefpe
Re: network shares
Post by fpefpe »
thx for the info -- the supported way assume you know what the share name are -- I have hard drive(s) connected to my router and the router used spaces and blanks
and the volume id to ID the directories and shares on each of the HD
Re: network shares
If you don't know the name you should be able to expand the Network branch of the Explorer tree to locate it.
