Version 15
Locked
Version 15
Version 15 of The V File Viewer has now been released.
Users can upgrade by selecting Check for Updates from the V Help menu.
If this doesn't work, you can download the new version manually from the Download page.
Version 15 has 3 main new features: High DPI support, Tab Sets and a new Highlight All functionality.
An explanation of these new features can be found here: http://www.fileviewer.com/V15.html
If your registration is more than 6 years old, you will need to upgrade your license in order to use the Version 15. You may trial the new version for up to 30 days. If you decide not to upgrade, you can continue using your current version, at no extra cost.
Please let me know if you have any questions or problems.
Locked
