I have W7Pro .. with all current updates, V14 with all current updates and I never seem to be able to use the "run as administrator" function. It is almost (99.9% of the time) greyed out...
It is becoming a pain to have to use other facilities to execute a program .. is there a solution that can be implemented so this is not necessary
Re: run as administrator
Run As Administrator is only greyed out if V is already running as administrator.I have W7Pro .. with all current updates, V14 with all current updates and I never seem to be able to use the "run as administrator" function. It is almost (99.9% of the time) greyed out...
In this case, Run/Execute should be identical to Run As Administrator.
To confirm, that V is indeed running as Admin, run the Task Manager (right-click on the Windows Task Bar a select Start Task Manager), select the Processes tab and enable "Show processes from all users". Then click on the View menu, select Select Columns and check "User Account Control (UAC) Virtualization" (towards the bottom of the list) and click OK.
If V is running as Admin, the UAC column in the Task Manager (next to V.exe) should say "Not Allowed".
