Printing PDF's from file finder
dbrannick
Post by dbrannick »
Within the results of file finder, I click on a PDF file and request it to be printed.
However, what is printed or displayed on the print preview is not the printed text but rather what appears to be postscript.
How can I request the pdf to be printed correctly.
version 14 sr2 x64
%PDF-1.4
2 0 obj
/F00 4 0 R
/F10 9 0 R
/F20 14 0 R
/F30 19 0 R
endobj
3 0 obj
/Type /FontDescriptor
/Ascent 891
/CapHeight 0
/Descent 216
/Flags 32
/ItalicAngle 0
/StemV 0
/FontBBox [-568 -307 2000 1007]
/FontName /TimesNewRomanPSMT
/Metadata 5 0 R
endobj
4 0 obj
Re: Printing PDF's from file finder
V can neither view or print PDF files - you will need to use a PDF viewer (like Adobe Reader).
There are two ways you can print the file from V.
1. From the File Finder, you can double-click on the PDF file to view it in the PDF viewer and print it from there.
2. From the File Finder, Ctrl+Right-Click on the PDF file (which will display the Explorer menu) and select Print. This will cause Windows to print the file using the default PDF viewer.
dbrannick
Post by dbrannick »
Option #2 works fine. I just wanted to select a group of PDF files to print without having to open each one to print. This option is just as simple and works like you indicated.
Thank you.
