Perhaps this is due to some simple error on my part, but my problem is the following:
I have created a grid for some very large datasets, but I need to adjust this grid to fit some files. When I load my saved gridlines and enable editing I am able to add new gridlines manually without any problem. But if I attempt to move any of the existing gridlines the program crashes. Moreover, it crashes so quickly that I cannot read the error message. It would be nice if I didn't have to recreate the gridlines that are currently satisfactory.
Is this enough information for anyone to have some ideas?
Thanks very much!
Crashes when editing grid
Re: Crashes when editing grid
I have posted a new service release (V13 SR5) which should fix the problem. You can upgrade by selecting "Check for Updates" from the Help menu.But if I attempt to move any of the existing gridlines the program crashes
If V still crashes, please select "Send Error Report" from the Help menu and send me the most recent crash files.
