New feature for ESC key
JeanMi31
Post by JeanMi31 »
Hi all,
I usually open V via the "Explorer Context Menu" of a file.
It would be great ;) if an option of the ESC key allow to close window and switch to directory listing of the file when started in file view.
Re: New feature for ESC key
It would be great if an option of the ESC key allow to close window and switch to directory listing of the file when started in file view
I will consider it, but I think there are already far too many options and I don't want to add another option that I think will only be used by a small number of users.
Note that you can already switch to the desired directory by pressing the Directory icon in the toolbar (or by pressing F4).
