Using REGEX expression in bulk file rename
dbrannick
Post by dbrannick »
I am having to rename about 10,000 files changing dashes to underscores. I'm selecting all the files to be renamed then right clicking and selecting the filename option modify options (regex) to do this rename. The issue I'm having is that it only does a single pass rename. Meaning if there are multiple '_' found in the filename I have to repeatedly select the modify command until no more are found. Is there a way to force the modify command to find 'all' occurrences of a search pattern?
thanks.
Re: Using REGEX expression in bulk file rename
No.
However, if all you want to do is change all dashes to underscores, use the Translate option instead of Modify (Regex) - this will do what you want.
dbrannick
Post by dbrannick »
Thank you. This will work. I guess I didn't see that command.
