I think V is a great utility and I use it as a replacement for Windows Explorer.
One thing I would like to do is drag a file to a zip file and have it be added to the zip. I can't seem to find anything in the help or forum on this; all drag and drop info revolves around dragging files to V.
Is there a setting or technique I need to change to do this or is this not possible?
Bit
Drag to zip file
Re: Drag to zip file
Sorry, but V can only view the contents of a ZIP file, it cannot modify a ZIP file in any way.One thing I would like to do is drag a file to a zip file and have it be added to the zip
