keep previous settings
djbeam
Post by djbeam »
In moving to a new system, is there a way to copy all the old favorites to the new system as the architecture will be very similar... and this will save a tremendous amount of setup time...
Re: keep previous settings
There are 2 ways of doing this:
The first is to use VClone to export the settings on one PC and import them on the other:
http://www.fileviewer.com/VClone.html
The second is to manually copy the V Registry key and settings folder. To do this:
1. Use the Registry Editor (REGEDIT) to export the following key to a .reg file:
HKEY_CURRENT_USER\Software\Prineas\FileViewer
You can then use the Registry Editor on the second PC to import the reg file.
2. Copy the V settings folder from one PC to the other:
C:\Users\UserName\AppData\Roaming\V (on Win7/Vista)
C:\Documents and Settings\UserName\Application Data\V (on XP)
