Date taken (when hover) is different from properties
GoofyKC
Post by GoofyKC »
When I hover over a picture the info that displays shows a different date taken then when I look at the properties of the picture (but not all of my pictures are this way). Is this a known problem?
Re: Date taken (when hover) is different from properties
The date shown in Properties is usually the date when the picture was copied to the PC. The date taken is the actual date/time when the photo was taken with the camera and is stored as part of the photo (in what is called EXIF data).
GoofyKC
Post by GoofyKC »
The 2 fields I look at both state "Date Taken" and they are different from each other.
I assumed that you were using V to display the Properties, but since V does not display a Date Taken in the File Properties, you must be using another program.
Exactly how are you displaying the other Date Taken?
Are the two dates totally different or are they always out by the same amount?
