Hi,
I registered V yesterday and I really like it. However, there's one option I can't find. When I open a file in the Viewer, and select the binary (hex), I can't find an option to copy it. When I select the binary, rightclick and choose to copy to Clipboard, it copies the text instead of the binary (hex) - which is OK, but Is there a way it can also copy the binary (hex)? Or an option I can adjust?
If not, wouldn't it be an idea to have that as well in a next release or so? "Copy as binary" option from context menu ?
Thanks
Copy as binary
Re: Copy as binary
If you start the selection by positioning the mouse on the left side of the display, the formatted output will be copied to the clipboard.When I open a file in the Viewer, and select the binary (hex), I can't find an option to copy it.
If you start the selection on the right side of the display (over the unformatted characters), then only the characters selected will be copied.
