User Commands not working in Dual Pane Mode
Yesterday I was in dual pane and tried to select two files , one in each pane, and pass the files to a User Command. But that doesn't seem to work.
Re: User Commands not working in Dual Pane Mode
User Commands are usually only executed on the "current" pane.Yesterday I was in dual pane and tried to select two files , one in each pane, and pass the files to a User Command
For them to work on files in *both* panes, you will need to create a separate User Command and use the %1F and %2F command options.
Have a look at the "Dual Pane (Split Mode)" section of the Help file.
